How to hide lines after cutting steel profiles?
7 REPLIES 7
Message 1 of 8
Leo_Ru8
324 Views, 7 Replies
How to hide these linesHow to hide these lines.jpg?
7 REPLIES 7
Message 2 of 8
RDAOU
in reply to: Leo_Ru8
@Leo_Ru8
These are 2D lines placed in the family.
  • You either need to treat them from within the family
  • Or you need to use linework tool and hide them using an invisible line
Message 3 of 8
Leo_Ru8
in reply to: RDAOU
But then the lines showing the shelves of the channel will be hidden.
Message 4 of 8
kadmonkee
you can try a masking region over the lines you want to hide
the if the circles are also hidden use the bring to front command for them
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Message 5 of 8
Leo_Ru8
in reply to: kadmonkee
It does not help with a large number of connections.
Message 6 of 8
kadmonkee
you only need to do this in your details
unless you are creating a detail for every instance of a connection.
thank you
Message 7 of 8
A couple of ways:
1. If the view is a section or elevation, use Linework tool to apply <Invisible lines> and use the grips to stretch the invisible extent where you want it to end.
2. Don't use lines in the family to present the member.  Set the 3d geometry in the family to be visible for all view orientations.
Message 8 of 8
Leo_Ru8
in reply to: ToanDN
Thank you!
That helped.
