Weekly New Knowledge Articles by Support team | Jan 12th - 18th, 2022
lim.wendy
Alumni Alumni
Message 1 of 1
lim.wendy
Knowledge articles written by our Revit support team to resolve the problem on your own. There're couple of incidents reported, do take a look at them for possible workarounds.
Published Date
Summary
Knowledge Article
Incident reported
13-Jan-22
When loading a titleblock family, Revit crashes
Revit crashes when loading titleblock family
Yes
12-Jan-22
When placing a family with a large radius, the program displays the curve as many segmented lines.
Large radius Revit family shows up as segmented lines
No
14-Jan-22
A model that had work completed is empty when viewed in Autodesk Construction Cloud
Previously worked on Revit model is blank in Autodesk Construction cloud
No
18-Jan-22
Without a clear pattern, it was noticed that opening and synchronizing the cloud workshared model (host) in Revit, takes longer than expected and often exceeds 30 minutes. Dozens of RVT links and nested links added to the host model are stored in the Desktop Connector (Autodesk Docs Drive).
Slow opening and syncing of a cloud shared model (host) in Revit that contains dozens of RVT links s...
No
17-Jan-22
Issue while changing desired stair height and desired number of risers when updating the "Actual Riser Height" of stairs in Revit
Issue while changing desired stair height and desired number of risers when updating the "Actual Ris...
Yes
14-Jan-22
Users reported that the estimated value and not the calculated value is shown on the report.
Insight Analytical Space generation shows estimated value from zone component load summary in Revit
Yes
14-Jan-22
Users reported unexpected behavior of 'has no value' or 'has a value' Filter Operators in Revit. When the filter is used in a case when the Parameter value was entered and removed, the filter will be not updated.
Unexpected behavior of 'has a value' and 'has no value' Filter Operators in Revit
Yes
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Replies (0)
