Weekly New Knowledge Articles by Support team | Apr 3rd - 7th, 2023
lim.wendy
Alumni Alumni
Message 1 of 1
lim.wendy
Our Revit support team has created knowledge articles for you to address the issue on your own. Several incidents have been reported, so be sure to review them for potential workarounds.
Published Date
Summary
Knowledge Article
Incident Logged
12-Apr-23
User reported that NetSideArea, GrossSideArea, Height and Width are not exported to IFC4 QTO for curtain walls from Revit
NetSideArea, GrossSideArea, Height and Width not exported to IFC4 QTO for curtain walls from Revit
Yes
12-Apr-23
The full name of the element is not visible when trying to rename it in the Project browser in Revit 2024.
The full name of the element is not visible when trying to rename it in the Project browser in Revit...
Yes
11-Apr-23
There is lack of most of the RFT files in Revit 2024 Chinese folder
Lack of most of the RFT files in Revit 2024 Chinese folder
Yes
11-Apr-23
Revit crashes and closes automatically when exporting CIS/2 file using Advance Steel Extension for Revit plugin
Revit crashes when exporting CIS/2 file using Advance Steel Extension
No
11-Apr-23
SMLX file exported from Advance Steel model with folded beams cannot be imported in Revit model.
The error message "Extrusion is too thin." might be shown when importing, and then no element is imported.
SMLX file from Advance Steel model with folded beams cannot be imported in Revit
Yes
11-Apr-23
Transparency of solid backgrounds applied through the filter is not included in the PDF print/export from Revit when vector processing is selected.
Transparency does not export or print to PDF with vector processing in Revit
Yes
11-Apr-23
Using Realistic Visual Style, the edges of the shadows are false, incorrect, blurred and are not straight lines in Revit
Using Realistic Visual Style, the edges of the shadows are blurred and are not straight lines in Rev...
No
6-Apr-23
How to bind multiple Revit links into a project in one go in Revit?
How to bind multiple Revit links into a project at once in Revit
No
6-Apr-23
We have a number of revisions on a sheet and run out of space.  How to prevent revisions renumbering after hiding them on the sheet?
Revision are renumbering after hiding them on sheet in Revit
No
4-Apr-23
When activating worksets / worksharing in specific files Revit crashes without any warning message.
Crash without warning message when activating worksets in Revit
No
4-Apr-23
Low PDF raster print quality in Revit
No
4-Apr-23
Users reported that railing type properties not exported to IFC using user defined property set from Revit.
Railing type properties not exported to IFC using user defined property set from Revit
Yes
4-Apr-23
Using Shared Coordinates and Planar Grid Coordinates in Revit
Using Shared Coordinates in Revit
No
4-Apr-23
Unable to access the files from Desktop Connector.
"You do not have permission to access this project[...]." when attempting to access multiple project...
No
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Replies (0)
