Wanting to know if there is a way to remove this line
The view is consistent colour with shadow, I created a wall at the ground level to its ceiling level, then created another wall on the 1st floor, but there is a clear boundary between them. The 2 walls are perfectly aligned on their plane.
I know rendering it will solve the problem but I just need to export a jpg on consistent colour view. Is there a way to remove the object boundary line if they are perfectly aligned?
Regards
ennujozlagam
hello, you can try invisible lines. thanks
Join grometry.
