Want to make irregular stair.
tw_you
Message 1 of 8
tw_you
I want to make irregular stairs, so please let me know. I can't think of any other way to do it.  please help
Replies (7)
Message 2 of 8
vitorbortoncello
Use Create Sketch option, defining the boundaries, risers and stair path
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
Message 3 of 8
ridantuo
You can also first model the stair and then convert it to a sketch based.
PICNIC: Problem In Chair Not In Computer.
Around 90% of issues can be explained by human error instead of an actual error.
Message 4 of 8
 I don't know what you mean by "irregular stair", but Component Stairs can manipulated using their Shape Handles.  Is this what you are trying to do?
Message 5 of 8
SteveKStafford
For that kind of gallery seating/stair I'd be inclined to use Model in-place and create the extrusions in section and then extend them as far as they would go in plan. You could also use a stair the left lower run and another stair for the left upper run. Then use Floors for the other seating and "floors/landings" required. The stairs and floors will not "join" up nicely and look monolithic so that's why I'd be inclined to go with "in-place" modelling. That would allow all the elements to look as if it was built "together".
Edit: I think you could accomplish it with the stair tool using sketch mode and multiple runs with different riser counts and height offset. Might be "easier" in-place though.
Steve Stafford
Message 6 of 8
tw_you
I've tried making stairs with sketches several times, but all of them have failed. I'll keep that in mind when I work !
Message 7 of 8
tw_you
I didn't know I could fix it with a sketch after drawing! Thank you.
Message 8 of 8
tw_you
Thank you so much! You helped me a lot.
