walls
walls
Message 1 of 20
walls
walls are not completely visible when i draw them.
i have just started using revit 2014
Replies (19)
Message 2 of 20
dzanta
verify the following:
1.  View Range is set properly (cut plane)
2.  Base and Top contraints of walls
3.  Walls categorie and subcategories are turned on (not hidden)
4.  Graphics Card is certiified to run Revit and has latest driver
5.  Start with new default Architectural Template.rft file and try again
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Message 3 of 20
What should be the base and top constraints in metres as project units?
Message 4 of 20
dzanta
top and bottom constraints of a wall can be anything you want.  For example, base of wall can be associated to Level 1 and top of wall can be 2'-0" higher than level 2.  Project Units for your revit model can be anything you want...Go to Manage tab, Project Units, select the unit measurement type you want to change and set it to what you want (i.e. Feet/inches/meters/etc.)
Message 5 of 20
And how are levels made?
Message 6 of 20
dzanta
go to an elevation type view (elevation, interior/exterior elevation, section, wall section, bldg section, etc.)
to to Datum Panel within Home Tab of Ribbon
choose Level command
draw the level via 2 clicks or pick method with offset
rename/change elevation height as desired
create associated plan views if necessary
Message 7 of 20
Are you maybe looking at a ceiling plan view instead of a floor plan view?
Message 8 of 20
It's a floor plan view! Checked!
Message 9 of 20
dzanta
have you tried copy/paste all 3d elements to a new file to see if it the file that is corrupt?
are you using a custom revit template file or the default architectural template file?
Message 10 of 20
M using revit project file!
Message 11 of 20
dzanta
can you send me your revit model?
give me your email address and I will send you a dropbox link for uploading the model.
Message 12 of 20
My email id is [email protected] Not yet done wid the model!
Message 13 of 20
dzanta
that's ok...i just want to look at it to figure out why the walls are not displaying properly so I can give you an answer.
Message 14 of 20
The walls are seen now! When i was checking the view range option.. i went to graphics display! And then i changed some setting of style! So i can see the walls now! Can u help me in libraries?? I don't have any!
Message 15 of 20
dzanta
the material libraries and family libraries are downloaded and installed by default when you install the software.
If you need the material library again, you can download and install them separately:
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcartic...
if you need the family libraries, you will have to do a repair/reinstall of revit.
Message 16 of 20
I think m facing prob in operating revit 2014! M not even able to uninstall it!
Message 17 of 20
dzanta
i can help you but my company charges for my time.  If you really need help, I can help you tomorrow morning before 8:30AM EST.
Message 18 of 20
I'll try to find a solutuion here.
Message 19 of 20
dzanta
log into your computer with admin rights
go thru control panel to remove the software
if this fails....download the Microsoft Software removal tool and use that
Message 20 of 20
I have tried both the solution
