Share parameters
Share parameters
Share parameters
I have some family parameters that are not being showed on the schedule since ther are not shared parameters.
How can I change them into being a shared parameters?
help!
jdiala
Attach a sample family and the parameter that you want to schedule.
maciejwypych
Edit the family.
Edit types
Select parameter
Modify
Select Shared Parameter
Edit...
New... (if you haven't created any shared parameters before, you'll need to create the file first and create a Parameter Group)
Give it a name and select the type.
OK>OK>OK.....
Done 🙂
