- Mute
- Permalink
- Report
I think my visibility settings and wall setting are correct. Also on in visibility graphics.
Any ideas?
Any ideas?
In your View Range change the Top to Associated Level (Attic). Offset 7'-6"
Change your Cut Plane Offset to 4'-0".
Looks like your cut plane is at the same level as your base.
Kory Skoog
BIM Manager
Your view range is not correct. Add a number to Cut Plane.
1" would even work.
Right now, the Cut Plane is sitting at the base of the wall -- NOT CUTTING THE WALL.
