How do I either prevent, or disconnect, two adjacent walls from locking themselves together? I have not used any locks anywhere, but when I want to move one of them, revit stubbornly insists on moving both. This has happened a few times, and I've put in some joints, but if this carries on my whole model will be filled with joints... I have to make sure I keep them separate until I think I've finished, and then move them into place - really not the easiest way to do things. In my latest case one wall is the wall below a ramp (which doglegs with a landing - another story, that, I had to put a 1mm gap between the two ramps to get revit to do it) and the other elements are the walls of a room next to the ramp. If I move the room into place and then try to adjust anything on it, it moves the ramp wall, too.
Thanks.
Solved by ToanDN. Go to Solution.
