Walls have window instance parameters??
PDSF
PDSF
I've never seen this one before: the walls of this project have taken on some of the window shared parameters. Any idea how this is even possible?
HVAC-Novice
Someone assigned project parameters to walls. Ask whoever did the project about purpose. You can see what unit they use when editing them.
assume the creator of those meant to make windows to use those values (not sure that actually would work....)
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
PDSF
That's it! Thanks.
