Is there a way to override the visibility (color/pattern) of a workset in a linked model?
I have a mixed use project with modular construction on the 2nd and 3rd floors. I have the modular model linked in thru ACC. I overrode the walls to show up a color to aid in defining scope easily for my DD set, this worked beautifully. My problem is the modular company modeled the site built walls on their own work set and I am trying to get them to "stand out" so I can create a "scope legend".....By overriding the walls in the linked model, Revit applies it to the worksets in the link. I am trying to override it thru their model so I don't have to duplicate the work.
The most simple idea I had was to just have them create a separate model of "site built" items only, but they are not very receptive to that idea.
on the attached image are:
green = arch walls
red = Modular walls
blue = site build wall modular created I want to stand out
Gelöst! Gehe zur Lösung
Gelöst von SteveKStafford. Gehe zur Lösung
You ought to be able to create a View Filter focused on Walls and the Workset they are associated with.
Steve Stafford
