Walls following terain
chmechailidis
chmechailidis
I am tryng to make a fencing for a residential project. In this specific project i want to have a wall to follow terrain's shape with a consistent height if 1200mm.
I know that its possible to it with railings if i select "pick you hast". Hoiwever, I dont know how to achive that with a wall (bricks).
I will appreciate any advice.
Thank you.
syman2000
You can built a railing with just rectangular profile that mimic the wall. Then host the railing on topo and it will follow the topo. See attached for sample
Not with Walls, but do walls really follow the top of ground - or are they built atop a stepped foundation which is buried below the surface?
If you really want the Walls to host to a Toposurface, then build your Walls as Panel Balusters in a Railing Type.
chmechailidis
Thank you for your contribution. I will check that out
constantin.stroescu
I'll use a combination Dynamo with Edit Wall Profile in Revit:
Wall on a Toposurface with Dynamo | Revit | Autodesk Knowledge Network
Constantin Stroescu
chmechailidis
Thank you very much for your help. It did work out.
