MITRE GUTTER EXISTING TO NEW CONSTRUCTION GUTTER
wisedrawing
Message 1 of 8
wisedrawing
Hi all
I cannot seem to join this gutter up
the fascia is an existing house roof fascia and already mitred and was fine - I have to demolish one gutter and replace a new gutter on the drawings - so thats easy enough, but in placing the new gutter I cannot get it to mitre up - join tools and trim tools do not work on gutters
all the usual factors are considered and no the issue:
- fascias are lined up yes
- horizontal and vertical positions are not changed
- its an existing fascia and it was perfect before with a properly mitred gutter so none of this should matter
also Southern Hemisphere here we spell it Mitre so not sure if that's different in the North - Miter??
Cheers
Darren
Replies (7)
Message 2 of 8
Yeah. Someone else that knows how to spell Mitre.  We're a dying breed, buddy.
Post your file.
...did you try slowly dragging the blue grip while holding your breath method yet?
Message 3 of 8
Check to see that the horizontal and vertical profile offsets match for both.
Message 4 of 8
You cannot miter gutter segments under different phases.  There are some workarounds:
- Add a small return segment to gutter to be demolished.  Create new gutter with the same return and join new + existing.
- If you insist to demolish at the miter joint, add a small return segment to the new gutter and use a void to cut it at the miter joint.
Message 5 of 8
I can.
...assuming that is what the OP is trying to do.  I didn't understand it that way.  But whatever.  He should be able to "phase" the miter (a.k.a. mitre).
Message 6 of 8
wisedrawing
Classic
I thought something was up when 0 search returns came up for Mitre
pretty sure I got all the matchings correct -
this probably brings up the point - an I force a mitre? regardless of matching etc. just make one?
cheers
Message 7 of 8
wisedrawing
Thanks for the work arounds ToanDN
see if we get to the bottom of it or not and I can use these in the mean time
cheers
Message 8 of 8
I can't open your file right now, but use this workflow:
  • Create a Mitered 2 Gutter condition by creating each Gutter separately (e.g. not in the same session).
  • Clipboard Copy/Paste Aligned to Same Place the Mitered 2 Gutters
  • Change the Phase Created/ Phase Demolished for each Segment. Example: Gutter 1a = Existing/None, Gutter 1b = Existing/New Construction, Gutter 2a & 2b = New Construction/None.
  • Change View Phase Filter/Phase to Show Complete/New Construction
  • Use Add/Remove Segment tool to select eave @ 1a.
