Walls following terain
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
chmechailidis
563 Aufrufe, 5 Antworten
I am tryng to make a fencing for a residential project. In this specific project i want to have a wall to follow terrain's shape with a consistent height if 1200mm.
I know that its possible to it with railings if i select "pick you hast". Hoiwever, I dont know how to achive that with a wall (bricks).
I will appreciate any advice.
Thank you.
5 ANTWORTEN 5
Nachricht 2 von 6
syman2000
als Antwort auf: chmechailidis
You can built a railing with just rectangular profile that mimic the wall. Then host the railing on topo and it will follow the topo. See attached for sample
Nachricht 3 von 6
Not with Walls, but do walls really follow the top of ground - or are they built atop a stepped foundation which is buried below the surface?
If you really want the Walls to host to a Toposurface, then build your Walls as Panel Balusters in a Railing Type.
Nachricht 4 von 6
chmechailidis
als Antwort auf: syman2000
Thank you for your contribution. I will check that out
Nachricht 5 von 6
I'll use a combination Dynamo with Edit Wall Profile in Revit:
Wall on a Toposurface with Dynamo | Revit | Autodesk Knowledge Network
Constantin Stroescu
Nachricht 6 von 6
Thank you very much for your help. It did work out.
