Walls don't show up right in the plan...once fixed, the elevations don't show up
Message 1 of 10
Revit 2018.
On the floor plan sometimes half of walls don't show up.  I fixed that by changing the visual style to wireframe.  Although it doesn't work with the elevations or building sections, and sometimes the hatch patterns just refuse to show up and print even though they are there.  It'll be one roof (a hip) and some of the hatch will show on one face, but on another face it won't.  It has turned into a nightmare
Replies (9)
Message 2 of 10
cbcarch
-What does a 3D view look like? Is everything there? -Try staring a New Project, draw 2 walls, and see if Plan, Elevation and 3D Views look correct. -If so, there is something wrong with your project. If not, it might be bad Revit install, or a graphics/PC problem. -Does all your other software run correctly in your PC?
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 3 of 10
It's not clear to me what you're describing. Can you post a picture or two?
...sounds like this is exclusively an issue with the hatch pattern. Have you tried using a different pattern?
Message 4 of 10
elevation
Message 5 of 10
Message 6 of 10
tried posting a two pictures... I guess I didn't do it right.
Message 7 of 10
You know you can post your file here? Attachments=> Browse Files To Attach. That might be easier.
Message 8 of 10
building section
Message 9 of 10
Do you know how to Print Screen? No, not literally. I mean by using the Print Screen key on your keyboard.
....frankly, I thought my suggestion to actually post the file here was brilliant. But, that's just me. Just seems that that would be the easiest way to help us understand you. These iPhone photos aren't doing it for me.
Message 10 of 10
...iPhone photos? It is clearly a Samsung Galaxy S8 with f/1.7 photo
