Walls are phased correctly, but displaying wrong
Nathan-ADI
Nathan-ADI
In this demo plan, There are a group of walls that are exactly the same as all the others other than being only 4' high instead of 11' high to the next level. The low walls are not displaying properly, even though they are phased the same as all the others. I played with the view range cut depth and it needs to be higher than 4'6" in order to display some windows properly, but these walls are not displaying unless the view range cut depth is under 4'. Any suggestions??
Nathan-ADI
I solved it by lowering the "bottom" of the view range... I should have known that.
