I have downloaded a family from BIMstore and when i place the window on to a host, the cill height is labeled 'Window Head Height' i have been looking around the family parameter settings but cant seem to find where i can change this, any help please?
You will have to go and edit the family and change the name of the parameter if it was wrongly labelled. Check the elevation views and see if the parameter you want to edit it is in fact window head and not window cill and check wether the parameter flexes when changing the heigh value.
Here is the Family, as ive looked into it more there are all sorts of problems with parameters that are not allowing me to produce a schedule that is legible and consistent, i am still currently working on it however this help is greatly appreciated, thank you
