Wall Wrapping Problem
I am wondering if there is a way making wrap into window below? Attached image is of wall with window family and jpeg which desired detail. I've set the wall layer and wall closure in window family, but how to extend wall exterior layer material to window subframe like as jpeg.  I want the finish layer of the wall to go till subframe.
Thanks in advance.
indiana_j0nes
Can you share your Window family?
Usually you will need to play around with the opening offsets to achieve this.
Cheers, K
Kunal Tuljaram Gaidhankar
Of course,
For a reason, I could not download a file to forum, you can download the family file below.
Thanks in advance.
https://wetransfer.com/downloads/81096cee3e1ee5fd04c22a427c9078d020191113112652/d7d8e01975d755dbe8c4...
