Wall with union elements
Message 1 of 19
a) trying to do a wall with join elements.
Do not undrestand why can join elements at top and not the base or the contrary.
Furthermore layers can become with "variable thickness" (airs and brick) are no more deleted.
Before create the base cancel a layer.
b) the union elements are not visible in elevation ore 3d view but only section, right?
Thank's
Replies (18)
Message 2 of 19
hey
are all the used material structural one ? or some of them are finishing layer ? and u can take them out of the core layer , maybe this can work in you case !
Message 3 of 19
let me know what happens with you ,
if you find i deserve a Kudos do not hesitate to offer it for me and a solution could be great in case of the right answer
Message 4 of 19
If put non structural layer out core say me " functional priority of layers can't be elevated from core boundary to final layres.
Put the correct function for layers no- structural. However the problem with divided wall persist.
Cheers
Message 5 of 19
Changing color for insolution have the join for elements at the top in property wall (not in the base) and not in section.
Furthermore there's a little piece of air that is distinguish from the rest both in propertes that in section. It's dimensioned in property but can't be dimension in section.
Thank's
Message 6 of 19
can you upload your file so i can scan it ?
Message 7 of 19
I uploaded yet!
Message 8 of 19
Matteo, I am posting this in reply to your PM. It is still unclear to me what your issue is though. Is this what you mean? See attached.
Message 9 of 19
Thank's!
How did you do?
Inser a little part at base to garanty the continuity of insulation?
For 3D view?
Many thank's! 🙂 ;))
Message 10 of 19
Is that what you were talking about?! That was simply done using Assign Layers. Did you see other change I made? You had the Air Gap incorrectly constrained, which prevented it from extending to the full height of the wall. Now it does.
Give me the solution if that solves your problem.
Message 11 of 19
Can you do some screenshot from my original .rvt, please?
Thank's
Message 12 of 19
I sent you the RVT file, Sir.
Message 13 of 19
Yes but would to know how you do.
Message 14 of 19
I ain't posting no screencast for you, Matteo, if that's what you mean. There are plenty of resources on line for that. I've already indicated the tool to use: Assign Layers. Google it.
Message 15 of 19
Hello, I use the command assign layer and undrestand how is do but... I ask why can don't use the command join for both side (top and base) because at final can't do that.
Furthermore, (attach 2) why the layer of air arrive at m 5,70? There no command in property in which I can establish the lenght of layer.
In addition to this a saw I can annotate the wall only from a bondary from air and left side insolution, but don't undreatsand the reason. It's not depend on the location line of wall because a put finish ext wall for both (numbers in rectangulars red).
Many thank's
Message 16 of 19
. rvt file in 2016.
Message 17 of 19
我会将这个本地化版本翻译问题报到对应的本地化团队的。
Message 18 of 19
@Anonymous: You are becoming a pest, Sir. Please do not not send me anymore Private Messages. They will be deleted - unread. If they persist, I will report you.
GOODBYE.
Message 19 of 19
@barthbradley
Sorry, I think you don't undrestand when a person joke and when not, (before I'm joiking...).
Writing is a form of neutral communication and hardly understood if written badly (as in my case).
For the rest, I have never received such messages from anyone in a forum...
Ps. Sorry for my very bad english Sir. Many thanks again for early.
Many cordial greetings
