Message 1 of 10
05:35 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I would use an in-place model void set to cut the wall geometry to do something like that.
I'll use a Wall based or Face Based Family created with a Void with parameters and then loaded into Project . The advantage of this method is that you can use as multiple instances in the project.
Constantin Stroescu
I testing this solution with a parametric family :
But the void is not created in the wall :
[edit] I joint the Family.rfa file
you have already solved the problem , but anyway I post also my screencast , maybe it will help somebody..
https://knowledge.autodesk.com/community/screencast/5105a1b5-7bcf-42bb-ac6c-577795626b0b
Constantin Stroescu
"you have already solved the problem ... "
No ... sorry but no, my problem is not solved ... the wall don't accept the void of my family ![]()
It works here. By the way, the family does not flex properly to different wall thickness. You may need to look at that.
try it now - I've load a Depth Parameter instead of a Locked dimension...
Constantin Stroescu
It is not the problem ... I find it : The wall and the family instance was not on the same phase :
Thank you very much ! ![]()
