Wall with different width
Message 1 of 9
Is there a easy way to create walls with these gaps in the middle? Seems to be walls with different width and I have no idea how to do that faster than making a different wall type to each width.
Replies (8)
Message 2 of 9
Just frame it with typical width walls. The void space between is a condition, not a wall.
Message 3 of 9
That is how I am doing right now. Is it possible to do it drawing the outline and then to fill it with wall?
Message 4 of 9
Not following you. Are you working with a CAD import/link? If so, just pick linework to create the Revit wall type you want. Pay attention to wall justification. You don't want to use "Wall Centerline" obviously.
Message 5 of 9
Yes, I'm using a CAD drawing.
In this part for example, I'll have to use different wall width and then I'll have to trim them (I have no idea how to do it).So I was wondering If I could draw all the outline of the wall and then fill it with wall.
Message 6 of 9
Use the Trim command or Grip edit.  For the example of the pointy end you show, you have to draw another wall to turn the layout from a triangle to a trapezoid.
Message 7 of 9
I've tried "trim" this part, but things got ugly (literally)
Any thoughts?
Message 8 of 9
Yes, I have a great suggestion: Model it exactly the way it will be built. What I see is a 2x6 wall following a chalk-line that jogs a bit before it intersects with a 2x4 wall (which just happens to be perpendicular to it).  A 90 degree corner: the best kind -- and probably what the architect had in mind.
Message 9 of 9
@Anonymous
I am on board with @barthbradley.
