Hello Team,
I am working with walls and I found that in my revit 2018 & Reivt 2019 Walls types are not available. I need solution to add all types of walls in my rvt 2018 & RVT 2019 session.
Please find attached Snaps with details of all wall types. I want to add all those wall types in my RVT 2018 & 2019.
Solved by Alan.johnson1970. Go to Solution.
Open an .rvt project file that contains the wall types that you want
Then use Transfer Project Standards (Manage Tab)
Check none and scroll down the list until you see Wall Types,
Tick wall types and OK. You can then overwrite or bring new only into your new Project
