Wall Type Menu not scrolling down
JasonLLINDNER
JasonLLINDNER
Hi
I am trying to find out why the wall type menu is only showing Basic walls. I cannot scroll down to Fassade wals and stacked walls
RDAOU
@JasonLLINDNER
The Wall type Drop Down Menu has a search bar... Type in a keyword like Curtain or Stacked or System Panel and it should jump to that section
You can also click edit type after starting the wall tool and you will find the complete list therein under the Type menu.
JasonLLINDNER
@RDAOU
Thank you I can work with that as a solution but this does not fix the main menu in the properties window on screen
RDAOU
@JasonLLINDNER
If you are not too picky about your screen resolution and your 4K screen...Change the screen display settings as follows:
  • Text/App size 100%
  • Display resolution 1920 x 1080 (can slightly vary 1 step up 1 step down - more is not recommended)
PS: not a universal fix. Different versions may behave differently
This is caused by the Windows Display Scaling value over 100% (usually 150% or larger) to make text legible on 4K screen. Changing the display scaling to 100% and reduce the resolution to 1920 x 1080 will fix it if I were you I would try to find a happy medium with Display Scaling and Resolution. Start with 1920 x 1080 @ 100% and gradually increase them add see if you can still scroll the type properties in Revit. You may be able to make it work at 2.5K @ 125%, for example.
