I have created a Sweep profile according to this video (https://youtu.be/PND9RA0OYLc?si=FDwCwd1t5PfhUCYY&t=115), but it doesn't create a proper opening for a curved door or window. It's okay for rectangular or square-shaped openings, but not with curved ones. What can I do?
The curves are not cutting the way you want, but neither are the cuts at the bottom or top of the window. The Revit handles a wall sweep is to sweep the profile along the full length (if horizontal) of the wall. A vertical opening will cut the profile neatly parallel to the profile, a horizontal opening will completely cut the sweep at the origin.
The only way to cut wall sweeps on a curve is to use an in-place mass solid form joined to the wall sweeps.
Thank you. It works only when I create the in-place mass and join or cut the geometry, but once I add a window, the issue remains the same.
You can remove the opening from the window family, but you'll have to do a lot of work to apply this to every opening/door/window in the cladding. Is it necessary to model the cladding at all? I would add a wall layer with the correct thickness and apply a material to it that had the right appearance in elevation, then I'd just use a repeating detail to show the cladding in section. This would only need to be done in a couple of places and would save you a lot of time and effort.
@Lachlan-JWP wrote:
@ToanDNI get the same issue when using wall reveal instead of sweeps.
That is because your reveals are very wide. OP reveals should be minimal.
