Facade brick pattern doesn't show on Dalux platform
fga_hnap
fga_hnap
Hi there,
I have a graphical issue when I upload drawings from Revit 2022 through Dalux plugin.
Dalux is a platform where to share documents, drawings and models in Denmark.
I have installed all the latest versions of Revit 2022, Dalux plugin and windows updates.
The issue consist on the brick pattern that doesn't show on facades, after uploading the files through Dalux plugin.
Dalux support suggested to export the view as DWF and open it on Design review, which I did, but the issue is still there (see screenshots attached).
Dalux said that is an Autodesk issue and not their issue.
Is there someone who had the same problem? Any suggestions?
Thank you in advance.
Have a good day.
Fabio
BIM Coordinator
CL-Vesti-Olsen
Community Visitor
Community Visitor
Hi Fabio
What "Pattern Type" are you currently using? Usually "Model" patterns shows up on Dalux just fine.
With kind regards
Chris
BIM Coordinator
