wall structure layer less than 1.6 mm?
4 REPLIES 4
1222 Views, 4 Replies
Curious about the minimum 1.6 mm limit on wall layers: Is this an arbitrary number, or is it a result of the accursed imperial system of measurements? Here in the rest of the world, we do have materials, such as metal sheets, that are 1 mm in thickness. As a result of Revit's minimum thickness of 1.6 mm, I am having to borrow thickness from other layers. It is a bother, and results in inaccurate representations.
As a representative of the rest of the world, we would like this changed. All apologies to colleagues in the United States, Myanmar, and Liberia.
4 REPLIES 4
L.Maas
L.Maas
If it has something to do with imperial system I do not know. As far as I know the limit is 0.8 mm
Revit (without tricks) will not draw lines shorter than 0.8 mm. So this is not only limited to wall layers.
Louis
Please mention Revit version, especially when uploading Revit files.
Louis
BEE_Design
in reply to: L.Maas
BEE_Design
Hi EnlInt,
I'm interested in how you managed to get 0.8mm thickness.
Through my approach I can only get min thickness of 1.6mm.
Screenshot attached.
Thanks!
Best,
LSY
Chasing BIM Architect ideal in HK with GeForce GTX 660 Ti, Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz, 16.00 GB RAM, Mircrosoft Windows 10 Home.
Hi EnlInt,
Thanks!
Best,
LSY
planner.suite
planner.suite
@Anonymous, are there any plans to allow thicknesses less than 0.8mm?
RDAOU
in reply to: planner.suite
RDAOU
@planner.suite
Instead of reviving such an old thread, you might want to start your own. And yes there are more than a couple of ways that allow you to work around the 0.76mm limitation
@planner.suite
