Hello, why does Revit switches my dimension input to a fraction? For example, I input 6'-7.2" and click enter then it displays 6'-7 51/256". I don't like it I want to remain as 6'-7.2". I provided pictures so you can take a look. Thanks
Gelöst! Gehe zur Lösung
Gelöst von ennujozlagam. Gehe zur Lösung
try to change your dimension style > edit type > units format > setting value and see if helps .thanks
I do not believe that the currently available units in Revit allow for such formatting...Is that even a conventional format?
The available unit formats are
