Wall schedule not showing volume amount.
kavlaks122
kavlaks122
Hello!
I have added a picture down below with my problem, can anyone help me out?
Thank you in advanced.
martijn_pater
You've unchecked itemize every instance, so because your walls have different volumes they do not appear. Under formatting you need to set it to calculate totals for the volume.
calculate totalscalculate totals
constantin.stroescu
If you want the Volume to be shown when Itemize every Instance unchecked , then , from Formating >Volume >check Calculate Total:
Constantin Stroescu
