Revit DB Link failed to commit changes to database
Mustafa.Salaheldin
Mustafa.Salaheldin
I created an ODBC connection to an MS SQL server and I use it to export data from Revit 2020 to the database using Revit DB Link.
I try to export the sample Architecture Revit project that comes with Revit. For some reason the data commiting failes two times showing the following error messages:
then
and here is the exception message I receive:
Also I'm attaching a copy of the error report and the Journal file for that session.
By the way, I have no issue when I export to ODBC using File -> Export -> ODBC then select the same ODBC connection.
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
michael.coviello
Autodesk Support
Autodesk Support
Hello @Mustafa.Salaheldin
I understand the problem you're facing only happens with DB Link and not when exporting to ODBC using the same data source.
The screenshots relate to the [Materials] table.
Although the error code is slightly different, Does the solution help from this article to identify long data values on some of the material parameters.
-2146232009
String or binary data would be truncated
"The field is too small to accept the amount of data you attempted to add. Try inserting or pasting ...
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
Michael C
Technical Support Specialist
What's New in Revit 2023 | Autodesk University | Revit Blog
