Hello!
I have added a picture down below with my problem, can anyone help me out?
Thank you in advanced.
Gelöst! Gehe zur Lösung
Gelöst von martijn_pater. Gehe zur Lösung
You've unchecked itemize every instance, so because your walls have different volumes they do not appear. Under formatting you need to set it to calculate totals for the volume.
calculate totals
If you want the Volume to be shown when Itemize every Instance unchecked , then , from Formating >Volume >check Calculate Total:
Constantin Stroescu
