Wall not displaying correctly
I am drawing a multi-story apartment complex. On one floor all the lines of a my wall will not show up when drawing them on that floor. It only gives the appropriate width. I can draw a wall on a different floor and then adjust offsets and it shows up with all lines but if I start on this floor I only get width. It is set to "fine" also.
constantin.stroescu
check the view range and the height of the wall.
Possible , your wall is not seen in cut, but in projection ,from above....
Constantin Stroescu
That worked. The view range was way off. Not sure how I did that. Thank You
