Wall mounted object attaching to inside of wall
Message 1 of 11
I downloaded an object which was attaching fine to my walls until I got to another wall and it's attaching to the inside face.
First wall is gwb Finish on metal stud on gwb and the other is single CMU.
In the image it's the pegs.  You can see them on two walls and then on the top wall it doesn't look like they're there but they are all pointed inside the wall.
Replies (10)
Message 2 of 11
Turn on wireframe display, select the peg and click on the blue workplane icon next to it to flip it outside.
Message 3 of 11
It doesn't have those.  You're talking about the two arrows that face opposite directions.  Selecting it doesn't bring up any icons next to them.
Message 4 of 11
Share the family then.
Message 5 of 11
Message 6 of 11
Well I think the family wan't built correctly so the hook moves following the wall thickness. Share it.
Message 7 of 11
Yeah, I don't know families well enough to fix it.
Message 8 of 11
nothing wrong with the family.
...does this one work for you?
Message 9 of 11
It is exactly as I was expected.  Here is the revised family.
Message 10 of 11
@Anonymous : did neither one of the families that I and Toan built for you work?   Strange.
Message 11 of 11
They did!  Thanks.  Although, Toan's were 2019, so I couldn't use them.
