Wall Material Type Schedule
rkernPBQSM
rkernPBQSM
Can you create a Wall Type Schedule that show the various materials that make up a single wall type?  For example this information would be in the schedule...
In the schedule if I have Material: Name and don't itemize it looks like this (no materials)...
2021-02-10 10_24_27-Autodesk Revit 2018.3 - [Schedule_ Wall Material Takeoff - N5668 2018-1.rvt].png
If I turn on "Itemize every instance" then it has multiple lines for each wall type...
2021-02-10 10_26_10-Autodesk Revit 2018.3 - [Schedule_ Wall Material Takeoff - N5668 2018-1.rvt].png
Any method to list all of the materials under one Mark Type entry?
Thank you
Sure. You can sort and group and filter by a unique identifier.  Try "Mark".
...try  this:
kjskoog
Don't know if you are looking for this type of look but here's an example of I have done in the past:
To do this you need to check the header button in the Sorting/Grouping tab in Schedule Properties:
Hope this helps.
Kory Skoog
BIM Manager
Kory Skoog
PM/BIM Manager
luisPDAN6
Something like this?
It available as free trial in the Autodesk Revit App Store:
https://apps.autodesk.com/RVT/en/Detail/Index?id=1292607999323978622&appLang=en&os=Win64
rkernPBQSM
Can you order the material list to match the construction order.  i.e. siding first, then sheeting, then wood structure?  It appears to just list in alphabetical order.
