Well, I have good news and bad news. Mostly good news...
Summary:
- I found a way to fix the immediate need with your clever idea of using the standing seam reflective image. Thanks!
- Custom images appear to show up correctly in the viewer as long as they are not applied to a PBR-based asset.
- I still have no idea what is causing the issue with customized PBR materials showing black in the Viewer.
I tried your trick of using the OOTB reflective images for standing seam metal to create the elongated white soldier brick look to use for sills, headers, arches, etc. (To repeat from the original post, the reason for wanting no mortar joints running horizontally is that they make it too fiddly to get each instance aligned so none of them have joints across the face.) It worked! Not a perfect representation of brick and mortar, but it will get the job done.
I was wondering if it was something in the way I was editing the images or something with the software I was using to edit them. So, I tried editing using a different method and different software. No dice! Same result.
I decided to try some texture images from some other source. I got several different versions of soldier brick from Architextures. I ran several different tests before I finally figured out at least part of the puzzle. The issue seems to be something to do with applying customized images to PBR material assets!
In the attached Revit file, and Autodesk Viewer link, and screenshots you can see the current results.
- The geometry in the bottom is some of the objects where I used the standing seam trick to create the desired look for the brick trim.
- The two walls above on the far left are attempts to take old OOTB Revit soldier brick materials and use a generic color and image fade to try turning them white. It kind of works inside Revit, but the white is completely lost in the Viewer.
- The next four windows use the old (non PBR) “Uniform Soldier – Yellow” material asset as a base but switch the image to one from Architextures or one that I edited myself. They need a bit of work to get the bump files to match up, and I would still need to remove the horizontal mortar joints for my particular use, but they all show up correctly in the Autodesk Viewer!
- The next four windows use the new PBR “Brick - Soldier - Light Blend” material asset as a base and change the image to the exact same ones as the last four. This is the bad news. I still have no idea why these all work fine in Revit but come through black in the viewer.
- The last two walls are just repeats. The first a uniform brick material I turned white by using the “Brick Uniform Running bump” file for both the main image and the bump image. The second another of the walls using the “standing seam metal refl” image to approximate elongated soldier bricks.
Anyone have any idea how to get customized PBR materials to show correctly in the Autodesk Viewer?
https://autode.sk/3jBGt7s
