wall layers
wall layers
seamea12
Message 1 of 11
wall layers
seamea12
I can not modify layers of compound wall either in model nor in design options .I got such a info-see attached file
Jack
Replies (10)
Message 3 of 11
RDAOU
@seamea12
You have the layer already unlocked from the top...Can you specify what exactly are you trying to modify?
Unlock/Split/Merge/Assign Layer...,
Message 4 of 11
seamea12
It looks like opened layer but it doesn't work at all .I got info about error (see  attached my file)
Message 5 of 11
seamea12
Thanks for a info but I am afraid it is not what I am looking for .I have a compound wall with all locked layers .I'd like to open  layers of my wall . It seems to work and shows unlocked layer  but when I press YES button it shows error info!
Message 6 of 11
Jack
Expand the error message and what it says?
Message 7 of 11
seamea12
I attache next file with expanded errors as you asked.
Message 8 of 11
- Write down the two Element IDs and back out of the editor
- Manage > Select by ID > enter one ID then show that particular wall and its properties here (do it for both walls)
Message 9 of 11
seamea12
Message 10 of 11
RDAOU
@seamea12
From the error warning message you posted, the elements in question are in a Design Option set...You need to make that active or make it primary to select those items. You can do that either by managing the design options from the Ribbon>View Tab>Design Options or by using the design option menu on the task bar at the bottom of the view
Message 11 of 11
syman2000
Can you upload the sample file for us to look at?
