Wall layers using a curtain wall
2 REPLIES 2
stin421b
288 Views, 2 Replies
Hi, i am learning and using Revit for the first time, for my high school architecture class here in Denmark, so if this question seems a little stupid; i'm sorry.
I am constructing a wall that has wodden cladding on to sets of lists, one with a 400mm center-to-center spacing laying horizontally, and one laying vertically with 60mm psacing, both made out of wood. As the cladding is vertical the first lsit need to be horizontal and is made of 45*45mm wood and the second list is made up of 20*45mm wood with the short side being the spacing.
If i am trying to create this part of the wall in revit, howdo i add to the structure of a wall?
So far i've made a seperate curtain wall with insulation for the inside of the wall, and could do this for these studs too, but it would mean that once i start drawing the whole house i would nee several walls to create the wall that i would want.
There is an attachment of a drawing, which is similar to what i am trying to do.
I am sorry if this description could be a bit messy. I do not know the proper jargon for these things in english.
Thank you for your help and best regards, Stinus Jorgensen
2 REPLIES 2
in reply to: stin421b
Start here:
https://help.autodesk.com/view/RVT/2023/ENU/?guid=GUID-91584C23-7FB5-46DD-82D1-48F36F3B4804
There's a lot of good information at this link.
stin421b
in reply to: barthbradley
Thank you sir, you are very beautiful!
