Message 1 of 12
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Wall layers are not joining correctly, why?
Same walls, with same height, with same parameters?
Pictures:
Pictures:
You probably placed them with "Disallow Joins"...select the wall and click the T sign to re-allow Join
I think it was visual bug,
I just simply clicked on wall and selected "Select Joined Elements" then every wall fixed it self...
I didn't even save file after fixing, next time opening it all was already fixed.
No it is not a graphics glitch ...You are using Unlocked Layers with Base extension.... On the Ribbon
Or Alternatively:
NOTE: If you disable Join on both walls >>> You will need to manually invoke Join Geometry tool
Yes you are right, that wasn't glitch. Some how I adjusted a bit wall layers, and then pressed "Select all wall" I think that refreshed all lines and I though that that was visual glitch. In that other post I found what caused that.
Here what caused it and also fix (for people with similar issue):
That's not a glitch. It is the normal behavior of unlocked layers ever since that feature was there (I remember it dates back to 2009). That link to the incident is dated 2016, I wonder in Barth actually believes it is still under investigation!!!
There are 4 other workaround that article fails to mention, the most basic of which is Converting the walls to parts
PS: Please mark any of his replies as a solution...
LMAO! You get riled up so easily, @RDAOU! Now you are all worked up about my use of the word "glitch" (in scare quotes)??? Geez. Next, it will probably be my use of the acronym BIM. Oh wait; we've already been there and done that.
Take a nap dude. Maybe ease up on the meds too.
@barthbradley wrote:LMAO! You get riled up so easily, @RDAOU! Now you are all worked up about my use of the word "glitch" (in scare quotes)??? Geez. Next, it will probably be my use of the acronym BIM. Oh wait; we've already been there and done that.
What caught my attention was the link not your reply and not how/what you punctuate, the latter are of no relevance. In addition to what has been already mentioned, the link suggests 4 workaround (not solutions) 2 of which I also do not believe are suitable for a workaround:
Nah no war there ... that is just Barth's way of flirting 🙂
