anyone know how to build this fence family
8 ANTWORTEN 8
Nachricht 1 von 9
FacebookGroupMember
1695 Aufrufe, 8 Antworten
8 ANTWORTEN 8
Nachricht 2 von 9
I know
Nachricht 3 von 9
RDAOU
als Antwort auf: FacebookGroupMember
Modeling it using Railing is one way
Nachricht 4 von 9
Yup
Nachricht 5 von 9
The secret is in the materials. Need a good pbr material with a bump map for the slats and a material with an alpha map for the top part. The rest is just a simple railing with panels
Nachricht 6 von 9
Use the one in the attached ZIP file, or go here and download another one. Line-Based Array RFAs -- with Type Catalogs and Materials to boot!
CertainTeed Fence, Rail and Deck Systems CAD, BIM and SPECS - CADdetails
Nachricht 7 von 9
syman2000
Yes. I would built it as one family with visibility. You would have 3 visibility - post, panel 1 & panel 2
Once you have the baluster built, you would placed in Panel 1, Panel 2 and Post
Once you have the pattern setup, you should be able to achieve what you want.
Nachricht 8 von 9
yes_and_no
als Antwort auf: syman2000
Awesome
Nachricht 9 von 9
Thanks for responding. Certainteed seems to be a panel system with a photo of the open mesh above which is SOOOOOO not what I was looking for. I answered my own query. I created a simple baluster post with open mesh above. Makes for better fence. Only issue is that the the baluster is 6" wide and when you fill the pattern, the balusters either slightly overlap or have a slight gap between them. PM me if you would like me to share
