Wall Layers connections messed up after "Modifying Wall Layers", seems like then can't be with same height all?
cadedu22
Message 1 of 12
cadedu22
As tittle says,
Why it's messing up layers if all parameters are similar, but when all parameters are different every thing is fine with joining's?
Here is pic:
Replies (11)
Message 2 of 12
cadedu22
Here is test file,
Message 3 of 12
RDAOU
@cadedu22
If you want to continue using unlocked layers and Base Extensions >>> Use the Wall Joins Tool
Alternatively...
  1. Disallow Join (Right Click the blue end grip)
  2. Stretch Wall to allow Geometry to Join as per Layer Functions
Otherwise...follow reply on your other post
  • Use proper Layer Functions Structure/Substrate/Finish...
  • Use Join Geometry between Wall and Floor
Message 4 of 12
cadedu22
Big thanks once again,
This two methods are perfect, and helps alot.
Message 5 of 12
TIP: pay attention to layer functions.
About Applying a Function to a Layer of a Compound Structure | Revit 2016 | Autodesk Knowledge Netwo...
This setup is problematic:
FWIW. 😉
Message 6 of 12
Message 7 of 12
RDAOU
FWIW. 😉
Why is it problematic? because all have Structure Function?!
It is neither problematic nor it is a must to have different functions for different layers. Functions are applied on as necessary basis - the only restriction is the order/sequence  of hierarchy if various functions are used
When all layers have the same function => they have same priority and join is applied based on material. It is actually a solution for several situations in order to achieve certain joins
Message 8 of 12
You don't know what you are talking about - or you don't know what I'm talking about.  Which is it?
Message 9 of 12
RDAOU
I know very well what I am talking about and I am pretty sure that the set up you highlighted is not problematic, and it is not even relevant to the problem of the OP...if you are so sure it is, feel free to elaborate how or why is it problematic
Message 10 of 12
You are a legend in your own mind, @RDAOU.
Message 11 of 12
RDAOU
Ok if you say so...
I would still be interested in reading your point of view on how and why that setup is problematic. One can always learn something new even at an old age
Message 12 of 12
cadedu22
Thanks for info, I was more confused about - why Layer connections are messed, when everything is aligned perfectly?
