how do I import points into revit?
hi, I got from the survayor a points file, that is not only terrain but a whole bunch of other things.
I would just like to see those points in revit. :::????
Thanks!
RDAOU
@Anonymous
I use dynamo to place points (which are basically a family) at Coordinates....You can also go through Autocad or  Civil 3D generate the points from the CSV file and link that 3D file into Revit
syman2000
Sadly if you have a lot of lines and text, Revit won't show those points. Other time Revit will show if points when there isn't much text. Screenshot below shows those odd behavior.
Also I would use AutoCAD to extract those points using DATAEXTRACTION.
jvpantin2
Hi, @Anonymous, if you have the points in a CSV file, just create a toposurface (from Massing & Site ribbon), select the 'Create from import', option 'Specify points file'. If don't, convert the file to CSV, there are plenty of options, for example:
https://help.salesforce.com/HTViewSolution?id=000322733&mode=1&sfdcIFrameOrigin=null
¿Tu problema fue solucionado? Selecciona 'Marcar como solución'.
Así ayudas a otras personas a encontrar respuestas y agradeces a los miembro de la comunidad.
