Wall Joins
Wall Joins
jfjacques
Wall Joins
jfjacques
No matter what, I can't seem to get a join. Why is the corner next to curtain wall not appearing to begin with? Join issue?
No idea what's stopping this wall finish from joining at insert/ exterior.
wall joins always a pain in revit.
ennujozlagam
try to pick wall > select detach top/base > select the roof and see if helps. thanks
RDAOU
@jfjacques
They are not s pain, what you need to do is
  1. Tidy up the walls and clear overlaps
  2. Change Walls' End Wrapping if need to clean up corner looks/details
  3. Set the Walls Base/Top constraints properly (as well as the offsets)
  4. Select the wall >>> right click the blue Handle/Dot at its end >> Allow/Disallow Join depending on what suits the situation best
  5. Join Geometry with other element where needed
Once all the above are done properly you can use the Wall Joins tool to change between Butt/Mitter in particular locations where needed
Martijn.Pater
Your curtain walls seem to be interfering with the join, so perhaps try disjoining all those curtain wall points(?), see if that helps...
jfjacques
This is the very ****ing definition of a pain in the ass.
RDAOU
@jfjacques
Take a deep breath and one at a time...it gets easier with time and before you notice you will be an expert at it
