Wall Ends
5 ANTWORTEN 5
Nachricht 1 von 6
jfjacques
500 Aufrufe, 5 Antworten
Wall Ends
How to deal with this wall end? Create a new wall with the gypsum for the interior?
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: jfjacques
Change wrapping at end to interior?
Nachricht 3 von 6
RDAOU
@jfjacques
Yes you need a new wall type with a different Wall - Wrapping. If you are using that End Wrapping shown in the image elsewhere on the project, then Simply duplicate the existing type shown above and change the Wrap At Ends to whichever is suitable (Interior/Both/Exterior)
Nachricht 4 von 6
Martijn.Pater
als Antwort auf: RDAOU
There's this workaround for wall end wraps based on windows (see below link), so then you could do with one wall type perhaps although having multiple should be fine either way.
Control Wall Wraps at Each End of a Wall | Revit Products | Autodesk Knowledge Network
Nachricht 5 von 6
jfjacques
als Antwort auf: Martijn.Pater
yeah that's not really a workaround, that's creating more work for nothing.
Wall wraps and wall ends are a constant pain and seem like they would be an easy fix. ****ing autodesk.
Nachricht 6 von 6
Martijn.Pater
Well... don't shoot the messenger. Anyway, we have to work with what we have and not what we'd like to have I suppose... although you could submit improvement requests ofcourse.
Perhaps you could try drawing/modelling the wrapping seperately as a seperate wall (type), not sure what method would be easiest for your situation though...
