- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am currently working on a project with an A-frame style gable roof that also angles inward on the footprint as seen below.
The issue I'm facing is that the wall will not join to the roof correctly when using the "attach top" tool, likely due to the angled footprint of the roof. It either attaches outside of the roof and cuts out the inside entirely, or clips on one side.
When I shrink the walls to not quite touch the edges of the roof it connects just fine.
But as soon as I extend the wall to reach the full length of the roof the join stops working. Is this just another Revit issue that can't be fixed? Is there any workaround? Editing the wall profile is not a valid solution, as the edges don't follow the angle of the roof footprint then, leaving a wedge-shaped gap on either the outside or inside of the wall.
