Corrugated Wall With Basic Wall
vitorbortoncello
Advisor Advisor
vitorbortoncello
I have been struggling with creating  corrugated panels using curtain walls  in Revit.
A useful workaround is to use basic walls and roofs with void sweep profiles applied instead of curtain walls.
This approach can help achieve the desired corrugated effect.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
vitorbortoncello
Simply apply the void sweep after creating the walls and roofs. I will post the file for guidance.
Mullions and Empty System Panels:
eliseGSHTL
Works great, thanks!
