wall join issue
wall join issue
wall join issue
Hi, I need some help working out why the wall joins at the corners are not displaying neatly without the extra line extending out. Ive tried changing the wall join configuration but that does nothing. I think its a visibility or graphics setting somewhere. Any ideas?
Thanks in advance
MBBIM
Did you select everything and use the filter to see if there are entities within lines and such.
View depth maybe changed.
Graphic card issues update drivers.
Save project close startup again.
Post the file.
I played around with the view depth and that seemed to work.
