Wall is missing from roof view
Message 1 of 11
I am in the Residential Design book and I was supposed to edit the roof sketch to match the one in the book. Upon clicking the roof footprint like instructed, I realized that a wall was missing. I need it to adjust the roof plan. Any ideas of how to fix it or what is wrong? On the 3D view, the wall is the same as the other one, it is not missing.
Replies (10)
Message 2 of 11
gtdraftdesign
Check that the base constraint and the top constraint are the same as the visible wall.
Message 3 of 11
rendermaster
would you mind to add more snap shot, especially when you're editing the roof footprint.
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
Message 4 of 11
I resolved that issue by using another view, however, a new problem has arisen. Could you help? cannot.PNGcannot two.PNGcannot 3.PNG
I can unjoin the elements, which would not be a problem- it is the fact that it cannot create a footprint that I do not know how to resolve. Any ideas?
Message 5 of 11
rendermaster
add also slope on this part.....(see image)
just click on that line then click on define slope
Message 6 of 11
I did that and it is still giving me the same problems, sorry.
Message 7 of 11
gtdraftdesign
Seem like if you add that slope to the front gable over the entrance that it would confuse revit considering that you also have slope on the sides. I wouldn't recommend that you try to add that slope. Just keep slope on both sides. Are having issues with walls joining the roof after you finish laying out your roof?
Message 8 of 11
gtdraftdesign
Also, by the looks of your drawing, you want a hip roof over the structure. I'm trying to picture how you want your roof to look. The roof seems a little cattywampus. Start by explaining what you expect to see from your roof system.
Message 9 of 11
I was following the book's instructions and it had me draw a gable roof and I was supposed to turn it into a hip roof, and that is where I am having problems.
Message 10 of 11
I figured it out at long last, all of the slopes were not the same.
Message 11 of 11
rendermaster
nice to hear that.....good luck
