Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Wall inside Door Family
moraruandrei29
Message 1 of 13
moraruandrei29
Hello everyone!
Is there any way to have a wall inside a door/window family?
My endpoint would be to create something like this in the door family, it is very important that I have the centerlines (analytical models) of those small pieces of walls.
Accepted solutions (4)
Replies (12)
Message 2 of 13
L.Maas
No. Walls are system families and only existing inside the project. Therefore you can not have them to be part of a loadable (door) family
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 13
RDAOU
@moraruandrei29
You can nest a custom shared family (category: structural column or structure beam) into door family to give you that result
From the looks of that detail...this also seems like a part of a 3D printed concrete project. If so I would keep the concrete jambs with the walls and place either a non-hosted door or a door in a dummy wall
Message 4 of 13
What about just controlling the Inset of the Door/Window from the Analytical Center of the Wall it is hosted to?   And/or hosting the Door/Window to an Embedded Wall?
Message 5 of 13
moraruandrei29
Hi @barthbradley
Can you elaborate a bit on that? I do need the analytical models.
Message 6 of 13
@moraruandrei29 wrote:
Hi @barthbradley
Which part? Embedded Wall?  You can use the Cut Geometry tool to embed one Wall Type into another.  If you are asking about Inset, open a stock Revit Window, such as "Fixed", and look at how the "Window Inset" parameter works.
Message 7 of 13
moraruandrei29
Hi @RDAOU,
Thanks for your help, I very much appreciate all the work you do here guys!
1. I can't just place a column in the window family, as the column will have just a line as analytical model, therefore will not be printed.
2. The door is placed in a dummy wall indeed, it is doable, with workarounds, but I am trying to find an easier process, for adding doors and windows to these projects, instead of doing all this work for each window/door every time.
Again, thank you for your help!
Message 8 of 13
moraruandrei29
Hi @barthbradley,
Thank you very much for your input!
I understand how to embed a wall into another, the thing is, how to make it round corner.
Thanks again for your help guys, I very much appreciate it. Cheers!
Message 9 of 13
RDAOU
@moraruandrei29
To do what you are thinking of would then require that you add custom analytical lines separately as model in-place. SEE GIF BELOW ...
you can automate the above easily using Dynamo; however, I still do believe that walls should be kept with walls and doors placed separately in an architectural dummy wall...less hassle,  a more straight forward workflow which gets you all the analytical surfaces/lines automatically
Message 10 of 13
@moraruandrei29
You can nest a shared architectural column into the door family to create the rounded jambs.  They will join with the wall nicely when the door is inserted in a wall in the project.  Similarly, analytical lines can be added to the door family or to the jamb architectural column family as a shared structural family, without any geometry, just lines.
2022 file is attached.  It is a quickie without the shared analytical column, but you get the idea.
Edit: it's true that analytical lines cannot be added in a custom family per @RDAOU , you can add subcategory model lines in the shared column family in order to recreate/trace them as true in-place analytical lines in project.  When done you can turn off the place-holder subcategory model lines.
ToanDN_0-1631634163508.pngToanDN_0-1631634163508.pngToanDN_1-1631634182502.pngToanDN_1-1631634182502.png
Message 11 of 13
RDAOU
@ToanDN
Analytical Lines subcategory is only available in Project environment not in Family Editor...Hence custom ones are created as in-place
Message 12 of 13
Message 13 of 13
moraruandrei29
@RDAOU @ToanDN @barthbradley You guys are awesome. I just realized that I can create centerlines for the printer, using Masses. Sometimes the answer it's less complicated than you think it is.
Now I can use the columns for the door family for visualization purpose and with the analytical models of the walls + the in place mass, I can make it ready for 3D printing. I will post some results soon.
Thank you again guys! you guys rock this program!
