Callout tag
Callout tag
rodrigo.bezerraRD5KM
Callout tag
Hey there
Is it possible to fix the callout tag? Ex.: to be shown always at the top right corner.
Use can place the Tag manually using "Leader" and "Free End" and then remove Leader, if you want, without affecting the Tag Position.
@rodrigo.bezerraRD5KM wrote:
Hey there
Do you mean Callout bubble? If so, no.
Not quite. The category tag for views is a view title tag, and I wanted my callout bubbles to look like a View Reference (which was easy) but to be placed in a fixed location.
Sure I can place View Reference manually and try work something about the position on Dynamo, but I don't know if worth the effort.
Thanks anyway
RDAOU
Unless you are too picky and want it always at a specific offset from the top boarded, it is not worth the dynamo considering that you can simply place a slim callout >> then drag down the bottom grip and the Callout head basically remains at the top right...
