Wall in option only available as original
cbt990
cbt990
When i turn parts view on, I can't see the wall anymore.
I also can't add it back in manually by cut/paste
Revit is amazing
cbt990
man, i had to 2 force quits trying to set a new option as primary and then accepting.
Revit is amazing
hmunsell
if i understand your issue correctly.....  Its a visibility setting in the View Properties, set the parts Visibility to Show Original.
Howard Munsell
Do you mean you Excluded Parts? You can Restore Parts as well. Window around the wall and you should be able to select the Deleted Parts to Restore. Restore button is on the Contextual Tab.
No issue showing parts and walls in a design option.
