Solved by dwills. Go to Solution.
I still can't figure it out,
Will you elaborate..?
Where is top-base detach..?
I am having the same issue with my walls. I give them a base restraint but I am unable to change the top restraint from unconnected,
Any Ideas
No issue doing that for this copy. They maybe attached to a floor slab above in your original model. If that is the case, select the walls and choose Detach Top/Base from the ribbon, then Detach All first. Then changing Top constraints will reflect on the wall heights.
Since you are new to Revit, pay little attention to all the Revit pop ups.
usually while editing the floor above, the following message pops up...and if you
click " Yes " to this , all the walls below will end up attaching to the floor...
so always click " No" to this message..
Cheers!
Well I think that the walls are attatched to the cieling that's why ur not being able to change their heights
After creating a roof above the walls you always get this message
Now to detach the walls click on them then you'll find this up:click on it after selecting the walls then click on the ceiling or roof and they'll be detached ! 🙂
if the "detach from top/base" doesnt do it- see the "detach all" button above the properties. That did it for me.
